- Joined
- 7 Oct 2025
- Messages
- 9
- Reaction score
- 6
- Country
Hello,
A boiler was given a ID because "gas rate failed" and "pressure at appliance failed". However, the guy who performed the tests signed the Responsible Person/Gas User box and not the Gas Safe Engineer's box, and vise versa, so I'm not even sure the paperwork is valid.
In any case, looking at IGEM/G/11 Edition 2 the only item that seems relevant is 7.7: "Flueless or flued appliance with visual signs of incomplete combustion at a main burner and/or within the heat exchanger: 2. Flued appliance AR.
As far as I can see, there were no signs of incomplete combustion and the boiler flame has never gone out, and has been running quite well for the last 10 years.
Should a boiler be given ID/AR for these reasons. What is the justification based on GEM/G/11 and/or common sense?
Lastly, it's a system boiler, and he had the hot water tap running continuously when taking measurements. The hot water cylinder was full of hot water as it was early morning and I hadn't had a shower. Wouldn't the hot tap be turned on for combi boilers only?
Many thanks.
Many thanks.
