Baxi 105e inlet manifold
29 Aug 2020
Can anyone tell me how to find the filter on the baxi 105e inlet manifold?
Good video but the 105e also had the filling loop connected to these valves . bit of an omit from baxi
Hmm, I saw this on the video, but he said it was on the later Duotec and Platinum ranges.
Hi again when I drain the boiler down to clean the filter im also thinking of changing the pump as it's a bit noisy. Is it ok to just fit a new pump head ?
Don't forget silicon grease on the pump rubber washer and take the screw out of the automatic air vent
Any tips on refilling the boiler? It usually takes me ages to get all the air out
Just about to start changing the pump and was looking around inside the boiler. Should the pin in the picture go flat ? , that's as far down as it goes
That looks ok as it's not touching the micro switch . It will probably drop further when the system is cold
