- Joined
- 29 Aug 2020
- Messages
- 132
- Reaction score
- 5
- Country
Can anyone tell me how to find the filter on the baxi 105e inlet manifold?
Looking at the photo the end of the cold inlet pipe, remove the blank nutThis is in the service book Im not sure where it is
Hmm, I saw this on the video, but he said it was on the later Duotec and Platinum ranges.Good video but the 105e also had the filling loop connected to these valves . bit of an omit from baxi
that is the venturi completely different part from what is being spoke about in video. you want the filter in the last valve on right hand side (22mm pipe )
yes but have look on ebay you will get legit old style pumps heads quite cheapHi again when I drain the boiler down to clean the filter im also thinking of changing the pump as it's a bit noisy. Is it ok to just fit a new pump head ?
Any tips on refilling the boiler? It usually takes me ages to get all the air out
