I’m feeling despondent so please go easy on me.
I’ve swapped 15mm hot and cold pipes for 22mm and where I could get access replaced the old 15mm CH pipe with new 15mm Hep20.
I’ve got a 35kw combi boiler that feeds a 5 bed house including loft conversion. There’s a main bathroom with separate shower, two en suite shower rooms and a separate shower in the loft (which will probably only get used by visitors)
The hot and cold mains is 22mm but the CH pipes are 15mm.
Mindful that the boiler might not be up to feeding the showers I got a G3 plumber round to test the flow and pressure and advise on adding an indirect hot water cylinder.
He thought the 35kw boiler would be okay for two showers at the same time (which is probably the most usual) and thought a cylinder may not be necessary. But he wondered, with 15mm CH pipes, whether the boiler would be up to the heating demand. (I’ve since estimated approx 22kW at delta50 across 21 rads.)
If I did get a cylinder he said the central heating needs 22mm pipes at its backbone (which is something I only discovered after the 15mm was replaced.)
So now I have three things getting me down.
1. Do nothing and regret it later.
2. Have inadequate heating.
3. Go for an indirect unvented cylinder and if so how far do I need to go to achieve the required 22mm CH ‘backbone’? And what is considered the backbone - does it mean all but the final metre to the rads? Or could it be 22mm in the rooms that we live in most? It would really hurt to undo all the new 15mm Hep pipe.
Are there any alternatives that don’t require completely re-doing the CH pipework?
