Outdoor shower no freeze
7 Aug 2021
Hi folks,
We're looking to put an outdoor shower on the wall of the house and wondering if you've any ideas for a cheap and easy one to buy that is less likely to freeze, or a good idea on how to set it up?
Thanks!
Is it for a pet?
Andy
I mean, that looks 10x better than the shower I had to suffer at uni. I'd wash under it
Hi all,
Thanks for the replies. It's going to be in use throughout the winter that's all. I've looked at heat tape, but don't have power. I've heard about auto-draining showers but can't find any.
It's not for dogs no.
Thanks,
Joe
Do you think something like this is less likely to freeze than a standard shower?
It's designed for outside. It will freeze the same, but the design should be that water doesn't get stuck in parts, and cause damage when it freezes.
Water appliances outside get ruined when liquid water becomes trapped between two parts that are blocked (eg valves or frozen themselves) as that trapped liquid water freezes it expands and bursts things
Your shower should be designed to avoid that entrapment happening - either because water is drained and doesn't get trapped or because the design is such that entrapment is unlikely (one open end that freezes more slowly than the other parts)
Ok great thanks everyone
