1930s Semi - Large Gaps In Brickwork
26 Aug 2025
Hi folks
Still working on our upstairs bathroom and having removed the old tiles and plasterboard above where the toilet was, I've got some pretty big gaps:-
Also got an issue where I'll have a gap where that 2x6 beam which you can see on the bottom right below the window is. I had hoped to leave it in place but my plan is to attach insulated backer boards to the bricks and it doesn't sit flush, so I'll have to remove it I think.
Someone had mentioned just using easifill or suchlike but I'm not sure - I was considering just using standard mortar but not sure if I need limestone mix?
Here's a picture of the back wall where I have the issue of filling the old backer board holes:-
Same issue here - Was just going to use some tube repair mortar to fill but will I be okay with that or could it cause problems down the line and I really need lime mortar? I just want these to be filled and hard incase I land up drilling right beside these gaps when attaching the new boards.
Cavity walls?
Just buy a ready mixed lime mortar or make your own up
Cavity walls?
I'd rather buy ready mixed if I can because otherwise I'm going to land up with a huge bag with very little usage I think. But then, I'm struggling to see this as a read mix option...
You will be surprised how much you will use.
Probably better to make your own up I think.
£20 ish for lime and buy sand as required.
Bin the remaining lime when done.
Thanks - Got a spare bag of builders sand from a garden operation earlier in the year, so I might land up doing that...
What's the consensus for the right mix ratio? I think I read 1:1:5 somewhere but not sure if less / more if I want this to be reasonably firm in filling those holes in the bricks rather than the gaps around them.
Watch YouTube as you will find demos of mixing lime mortar
£20............Double that at least
