Hi all,
I'm internally insulating a North facing wall in my house.
I've removed all the existing plaster and now I've measured up I think I'm going to have an issue with the reveals.
My original plan was 25mm celotex, 9.5mm plaster board and allowing for 3mm skim that comes to 37.5mm which on the right side reveal will come out over the beading for the glass.
The max I have available is 35mm, can I use a 6mm tile backer board and will it take board finish plaster ok? I've seen you can get 6mm plasterboard but it's stupidly expensive for a single sheet at about £70.
I could go down to 20mm celotex but I'd rather keep the extra insulation and lose the thickness in the finishing board, and I've already got the 25mm celotex.
Has anyone got any other ideas, the only other idea I've got is to stihl 10mm off the blockwork but that seems extreme and may cause issues with the lintel bearing.
Chris
Chris
