Of these options which will give better sound proofing?
9 Apr 2016
Due to cornicing I cannot fit a full sound proof solution on terrace party wall. The wall is 9m high with no joining joists or voids btw. So of my options which will give best soundproofing?
Leave existing blown 20mm lime plaster.
Strip to brick and pu foam bond Siniat soundboard.
Strip to brick and pu foam bond soundboard 50.
Any info appreciated, thanks.
Sticking board on with foam might work.
I've thought about it although not tried.
I will say expect it not to work as well as you would hope though. I think it will help but not block everything. Jmo.
That was my thought, that the foam would act like a decoupling.
I still expect to hear sound but would like it to be less than it is now, otherwise I’ll likely leave the blown lime
Battens not fixed to the wall but held off with resilient rubber pads for decoupling, then sound slab Rockwall 50mm in-between, then 2 layers of sound board separated by a specialist sound damping adhesive.
Anything less will be a waste of time and effort my opinion
Thanks for the reply, this is what I’ve read is ideal but I don’t have the space, only approx 25mm to work with.
In your opinion, would pu adhered15mm soundboard replacing the blown plaster give no better benefit than the existing blown plaster? Thanks
No an expert but did a lot of research when I did a wall.
Adding extra density will help but how much difference you will get compared to going the hole hog is debatable
Thanks for info man, appreciate it
Sound blocking is largely proportional to the weight of the barrier. A continuous barrier with no gaps is essential as noise comes through gaps.
I've found old lime plaster on laths very effective, because it is not only thick, but also heavy.
Replacing old ceilings with ordinary plasterboard, which is both thinner and lighter, is noticeably less effective. Two layers plus skim are not too bad. The soundproofing plasterboard is extra-heavy.
On a wall you can use sand and cement render, which is quite easy to work with even if you are no expert, also cheap and easy to knock up. My old dad was no good as a plasterer, so he used S&C with a hard plaster skim. I now live in an area where it is found as the standard method in many houses, including my own, from initial build. Older ones have a lime and sand render plus skim.
For you, easiest would be to patch up the original lime. You can re-bond loose patches by injecting PVA adhesive behind it then pressing flat with a board.
Fill in any gaps. Interior brickwork in Victorian houses is usually very shoddy, because it was intended to be hidden with plaster. The gaps will be unfilled between floor and ceiling, behind skirting, and inside cupboards.
