Hi Folks
I'm redoing our bathroom and having knocked away the old plasterboard around the window noticed a couple of wet spots on the interior brick work below the cill. I've highlighted them here:-
Under normal circumstances, I'd never have seen them as our sink / cabinet where based there.
Anyway, I'd looked outside I thought I'd found the issue with a massive gap below the actual pvc window frame on the outside:-
I filled that with sealant and had fingers crossed that would solve the issue. However, I dried the area off but after some heavy rain again last night there are signs of a small amount of water coming in again.
I'm a bit at a loss now as to where it could be coming from but just wondered if it was possible it was working it's way in through the lintel itself? If you look at the picture above you can see the paintwork was pretty badly flaked off. I'm not sure re what these old lintels were made of but is it possible it's porous and with the paint gone in places there's no protection?
I've gone over it with some masonry paint just now, so it will have a couple of coats by the end of the day and this is what it looks like from the outside:-
I can't see any other possible places for ingress, so is that poor paint work really a possible cause?
