Glow-worm Ultimate 30C - Leaking from PRV?
18 Jul 2007
I've noticed a leak from my boiler this last couple of weeks (since the weather turned cooler and the heating has therefore been running much more.
The water appears to be coming from the fitting where the pipe from the PRV exits underneath the boiler.
This looks like a 15mm copper pipe with a brass fitting where it enters the boiler. I can't tell whether the water is leaking from between the pipe and the fitting, or from the outside of the fitting but the water is definitely coming from here.
Is it normal that the PRV would be emitting water in normal operation anyway, or does this suggest there is a more significant problem which needs looking at?
If it is just the PRV or fitting itself, is this likely to be expensive to repair or replace? I see that Glow-worm offer a fixed price repair service however this would only be worthwhile if it's likely to be an expensive repair - if it's something relatively cheap I would prefer to approach a local gas engineer.
Not necessarily more significant problem, but you likely have a flat or failed expansion vessel or expansion issue.
Use a local for this
Any indication how much to expect to pay, if it's a failed expansion vessel?
I don’t unfortunately as everyone charges differently, but I think glow worm repair would be approx £350 independent would be at least half
