- Joined
- 1 Dec 2025
- Messages
- 2
- Reaction score
- 0
- Country
I'm due to fit some window sills under a pair of windows in our (old-ish) house. The wall that the windows are fitted to bows outwards slightly towards the middle. There is a radiator that spans the width of the windows which (naturally) does not bow outwards.
I'm trying to decide whether I should make the window sills straight to the radiator, or straight to the windows themselves. If I do the former, the windowsills will be somewhat trapezoidal, and the horns on the will be deeper in the middle than on the outside corners. But the gap between windowsill and radiator will even out and be nice and straight. If I do the latter, my concern is that the windowsills will accentuate the bowed character of the wall by providing two lines that converge to the deepest part of the bow. Given that I will have white windowsills against a coloured wall, I'm concerned this would stand out.
The attached diagram is slightly exaggerated, but hopefully demonstrates the conundrum. The true dimensions are something like 8cm from centre of window space to radiator, and 2cm from outside corners of window to radiator. So if I do option (a), the horns would be quite significantly different in depth (though the outside ones will be concealed by the gathered curtains).
Thoughts appreciated!
