Step bricks dropping
6 Sep 2016
My step bricks have slumped down over the years which I want to re-lay. can anyone tell me how I can get them out without damaging them please as I tried a crowbar which didn't work and I stopped for fear of chipping them ?
Drill a hole, in the centre of one, so you can insert a screw and plug. You can then lever the brick up using the screw, and a crow-bar. Get one up and the rest should be easy. When you relay that first brick, simply lay it with the opposite face up.
Good idea thanks but ideally I would prefer to not have to put a hole in one of them.
Surely one of them can be levered up, where the gaps are bigger? You can probably loosen them by digging out whatever's between them with a suitable screwdriver or similar.
I'd knock out the infill between slabs and bricks: it'll need reinstating anyway.
