tiling on wood
28 Jan 2011
Buckinghamshire
Hi folks, I'm about to tile a wooden panel (about 1000 x 500 mm). It's currently just bare wood. I have some flexible (powder) adhesive, wich I think is what is needed. I presume that the wood really needs to be primed/sealed before tiling - does it matter what I prime it with? ... and do I take it that I ought to prime/seal,the back of the wood as well?
I
Is the panel recessed to take the tile or will it stand on top of the surface?
The pros will lokely view it a bodge but I've used constructipn adhesive for this kind of situation several times with nary an issue.
You mean PVA? I think many would be tempted, but I've seen/heard many a pro disapproving (perhaps with good reason_. Anyway, I think I have some SBR, so I'll use that, and hopefully keep everyone happy :-)
Tube stuff: Pink Grip or one of the many alternatives.
No, don't use PVA.
Best solution would be to line the wood with cement panel if possible.
Failing that, SBR.
