Help! Bar Shower Valve Issue
25 Sep 2008
Renfrewshire
I have went to install my shower valve and the pipes are 5mm out the wall is tiled now and the pipe chase was filled so there is no play on the pipes.
Is there anything out there that I use to adapt and offset one of the pipes or is this going to have to be a smash the tiles fix?
Oh dear - as suggested - if you have set it up so it uses a fixing kit, then it needs to be bang on 150mm and if there's absolutely no play in the pipes, then unfortunately you'll need to get in there.
Yes there are dog leg adaptors
Could only be used if the op had used wall plate connectors or 1/2"x15mm female compression elbows
