I'm rather surprised by some of the things I'm reading. Does anyone know roughly how much current this glow plug is likely to need, and for how long at a time?
10 to 20 amps, but the time is variable. It depends upon how quickly the stable burn takes to properly establish itself. The start is closely monitored, by the control system. The tip of the glow plug, glows red-hot, to ignite the fuel, while-ever it is powered.
Once a proper burn is established, only the control pcb, the combined combustion fan/blower fan, plus the solenoid pump need to be powered. Call it around 1amp.
A motor, operates two fans, on either end of it's shaft, one end in the combustion chamber, the other outside, drawing air past the outside, and into the space of the room.
The solenoid pump, injects a squirt of fuel, into the combustion chamber, every time it is pulsed. In the combustion chamber is a wire mesh, which is kept hot enough to maintain the combustion, once established.
Motor/fan speed, and pump impulse, are varied, depending upon the demand for heat.
Mine, can be set to maintain either a room temperature, or you can have a continuous, manually pre-set level of output. That's the Chinese diesel heater.
The one fitted on my car, works similarly, except instead of heating blown air, it heats the engine coolant, and uses a little electric water pump to circulate the coolant. It is enabled, automatically, if the ambient is less than 10C, when the ignition is switched on, but I can remotely turn it on, ignoring the <10C. It then runs, until the coolant hits 76C, and ramps down, cycling back on at 73C.
The can be run on white/red diesel, heating oil, parafin, even Jet A1. Mine, in my workshop runs on the latter.
