Radiator tail not coming off
2 Dec 2025
Hi, any suggestions on how to take this radiator tail off? I've tried with a wrench and pliers but have damaged the thread whilst doing so. I've also tried a TRV tail driver on a drill but because the threads damaged it doesnt hold onto it well and just turns.
The images attached to this post are 1. close up of the damaged thread 2. the radiator tail in its original state
Pair of Stiltsons. You can't have damaged the threads by trying to undo it.
Why not use a tail allen key
That's a modern standard tail - the rad HEX key will only fit the old standard union type tails, i.e - the one on the left in the pic below
Pair of vise grips on the chewed hex will get that out. Threads will be ok as they're what's actually in the rad tapping.
Try some heat, maybe carefully use a bit of boiled kettle water?
THanks I tried using the vise grips on the chewed hex but it doesnt hold/grip onto it.
Hmmm - that's not right - good quality (CV) vise grips will easily grip that and take that out, as they are only brass. In all my years I've never had a case where grips wouldn't get a tail out like that, you need to get the grips locked on tight enough and as suggested, looking straight on to it, take it out anticlockwise.
no luck I'm afraid.
i've dropped some images in this post, am I holding/gripping it correctly and is it on the right part? (sorry im a beginner and learning)
What he said.^^
Turn the grips around then they will tighten as more force is applied.
