How long should a 12v Car Battey last?
I've a length of 2.5mm2 coax cable with croc clamps and have started numerous cars at the airport but allways run the engine for 10 minutes or so before attempting to crank the other engine, seems to work fine. Of course the 2.5mm2 limits the amount of donar amps, better for my car but still works well.
Some of them up to 200 amps. Simply amazing. Once the car has started it's not going to take too long at all before the battery is well on its way to being happily charged again.
Whilst alternators can deliver some large currents, that mostly goes to supply the car's accessories - lighting, fans, etc., rather than recharging the battery. The battery might take 20amps initially, but as the voltage of the battery rises, that will rapidly decline.
The only way to rapidly charge a battery, is to increase the charger voltage, which was what those old 'boost chargers' did. Increase the output voltage of an alternator, and you can expect your lights and accessories to burn out, instead, the voltage is carefully controlled, at a safe level, by the alternator, resulting in a slow recharge, over many hours (if the battery is near flat).
Yes, I've watched that a few times with VCDS, the charging current goes up to ~ 14/18A initially but literally for well less than a minute, even only 20/30 secs or less then gradually falls back to 2/4A, you'd require a tank full of petrol driving around IMO to recharge a flat battery, far better off buying a £20 smart charger in Lidl or the like.
Do you not think the car would have started on its own after doing that?
Mmmmm.
I abandoned jump leads decades ago, bloody awkward things to store in a family car & I never had much success with them either.
Always carry a compact jump-starter in the car these days, employ a mains charger for 24hrs every couple of months (high percentage of short journeys by SWMBO) & monitor both battery & alternator output on occasions.
Considering the importance of a good battery in a modern car it's not a horrendously expensive item to renew & I never mess about with one that shows early signs of unreliability.
Not mine, they are easily stored. My boot floor is designed for a full size spare, but only has a temporary type, in the well, with a fitted case for jack, wheel brace, spare lamps, and fuses in it. Around the wheel, I have wound a tow-rope, a screw in tow adaptor, and my lightweight jump leads. I've never needed any of them, but they are their if needed - You only find you need them, if you lack them :-)
I just bought a compact jump starter. I avoid using my car for short distances, as much as I possibly can. and so it can sit for extended periods unused, in the garage. I have a smart plug, set up to boost the battery, for 20 minutes, each day.
'Proper' size spare in my case plus wheel change kit & towing ring as supplied by the manuf. all in the well.
I don't carry a tow rope in the car though I do have a 4.5mtr, strop in my old 4x4 & I make it the other driver's responsibility to attach their end of the tow if a ring isn't available .. that way I'm not responsible for any damage.
