I have just had the old radiator removed and a replacement installed in a new position in the living room.
New radiator is not fully hot - the section near the bottom is not as hot as the rest.
The new radiator is a type 22 with a BTU of 6800. The old radiator was type 21 with BTU of about 5200. The pipes to/from the radiator are 8mm on a run of about 3.5m each way.
Someone has suggested to me that the problem could be the radiator is too powerful for the 8mm pipes.
Does this seem a likely cause and any suggestions for the best solution?
