- Joined
- 22 Jan 2007
- Messages
- 24,301
- Reaction score
- 3,628
- Country
It's just for basic protection, like a plasterer's trowel, nothing more.BTW - why use PVC channels over steel? Surely the idea is to less easily drill into wires?
I did have that thought too, to be honest.The wall boards or plaster will support the ends of the ceiling boards - you don't need bits of wood.
I don't bother; put the ceiling boards up first then butt the wall boards up to them with a line of adhesive along the joint. Ceiling board can't sag if it's resting on a wall boardMy understanding is that it's just for additional support for plasterboards?
Absolutely not. We haven't done that for at least 60 years. Ensuring the conduits are all properly earthed is such a massive pain in the arse, and so likely to fail, that it becomes a massive danger to have large sections of your conduits become live by one carelessly driven screw bridging from live core to conduitI'm now thinking cables in steel channels and pipes
Thanks for the concern but I have no intention of doing electrics (or plumbing) myself. Not least for insurance purposes - in that, should anything go wrong, I would need to prove it's been done by a competent person to validate any claim (it will be obvious the wiring is recent). But also because I am not qualified to do it.I don't bother; put the ceiling boards up first then butt the wall boards up to them with a line of adhesive along the joint. Ceiling board can't sag if it's resting on a wall board
One of these makes it easy to butt the board up while you get a few screws into it;
The professional electrician that you employ to do your wiring will never, ever run residential cabling inside metal conduit - they'll use RCD protection and bury wires to the recommended depth.
That you're floating the idea makes me gravely concerned that you're considering doing your electrics yourself and that you're asking the question indicates you're not what the law would call a "competent person" (i.e. properly electrically trained)
There is;But the bit I have struggled to get my head around is why there isn't something to stop you being able to drill into a wire in the first place? Because whilst RCBO will ensure nobody gets hurt - you've got to rip out the wire and redo all the good work again.
