- Joined
- 27 Apr 2008
- Messages
- 10,342
- Reaction score
- 1,214
- Country
So in my new bathroom the guys fitting it did an amazing job, not finishing until 9pm on one evening (they are returning after xmas) so that we had facilities over xmas and I'm not knocking them.
However the final outlets for the shower and basin go via a 38mm ish and 40mm pipes.
The one on the right is the shower at 40mm, the one on the left is the 38mm ish (not entirely sure) from the basin.
The shower white to grey joint to me looks very suspect and did leak at first, to me it's not straight.
FYI this is a view from underneath (where part of the kitchen ceiling fell down due to a leak).
What I'm thinking is that once the ceiling is repaired, there will be no further access to these joints so if they leak again I'm stuffed.
So what I'd like to do is convert them to glued fittings.
So first off can I get a 40mm 90 angle that will glue onto the shower PVC pipe top right?
Then I can change the whole pipe through to the outside and use glued fittings out there too.
Same with the smaller one on the left?
All I can see at screwfix are packs of 5 of each type of fitting so I'm hesitant to use them, I may have to have a trip to wicks/b&q instead.
