mixing Fernox leak stop and unknown inhibitor
15 Feb 2015
Nottinghamshire
Hi I have a Worcester Combi boiler 3 years old that is losing some pressure every 6 weeks for the past 12 months.
It is covered by the Worcester warranty so a Worcester engineer came out assessed it and said everything including the valves and expansion tank looks ok.
He said it is most likely a problem with a small leak somewhere in the pipework.
He suggested adding some leak sealer through a towel rad.
When the boiler was installed 3 years ago I am sure he put an inhibitor in at install although I cannot remember the brand.
My question is I have some Fernox leak sealer, is there a risk here mixing it with an unknown inhibitor in the system like sentinel?
There appears to be mixed comments online that this could form a jelly sludge and cause blockages?
thanks
Hi, thanks for the reply , the house has 16 or so rads in it so he advised finding a leak might be hard.
I have had a good look but unfortunately nothing obvious has reared its head.
The boiler has been checked out by a worcester engineer 2 weeks ago and he says is happy that it is not the boiler. still have another 5 years gurantee on it.
Just didn't fancy causing too much damage looking for the leak, would leak sealer be a shout?
thanks
Good advice thanks, maybe ill have another good look and try and find the leak.
I asked the same engineer about installing a magnafilter, he advised probably no point now being 3 years down the line.
Do you think it would be worth having one installed? thanks
As above try finding leak. If it's taking 6 weeks to drop pressure I'd be having a good look at all rad valves .
Take of heads of trv's and dust caps off lockshields.
Auto air valves if you have any can be another source of problems.
Just fit a decent system filter, difficult to understand why a boiler only 3 years old didn't have one fitted as part of install.
Thanks so much all for the helpful replies, after some rummaging I found the leak on a bleed valve as Exedon recommended, so saved me clogging up the system with leak sealer!
It was only leaking when cold so made it a challenge to find.
I nipped it up as it was loose and seems to have stopped leaking. It's a little rusty where it was dripping , I have seen worse but would you recommend to do anything to this area.
Thanks for your help a big problem solved!
These bleed valves seal against the raditor by compressing a rubber O-ring. This detiorates with time and this may be the cause of the leak. Nipping it up may stop the leak for a while but, if the O-ring is getting hard, then it might start leaking again. Eventually you'll probably need to replace the O-ring.
Hi sorry to open this thread again
I am looking to install a magna cleaner for my boiler but the space seems tight
At the top of boiler have in order
Heating Flow pipe, Cold mains, Hot water outlet and Heating return pipe .
Below the boiler
it feeds a single radiator only, no so connection to heating return from wider system. (Single rad flow and return with gas pipe and PRV)
The magnacleaner needs to be installed on the heating return which is above the boiler on the furthest right.
I am keen to install the adey magna clean pro 2 which needs at least 24cm + additional space for servicing.
The magnaclean atom would be better for tighter spaces with 12cm of space required, however I have 16 rads so may not cover. Also wonder if it does leak will be dripping straight onto the boiler.
I can access the pipework in the small loft space above.
The wiring for the thermostat can be moved around.
Wondering what the best solution might be to install one considering the space would be keen to avoid servicing it above the boiler and bring down height wise?
thanks
