Spot on shippers.
Just checked again. My socket has a keyway between pins 1 and 2, but the diagram in your link shows no key.
No.Is there a standard convention for possibly 1 = +ve and 2 = -ve?
My multimeter is showing -0.21v dc when connecting pos to pin 1 and neg to pin 2.I would not think there is an infallible convention.
What voltage does a DC multimeter show on the pins of the underwater vessel?
I'm not sure how you know what kind of charger to use. The vendor seems to consider a 'smart charger' to be essential (whatever that may be). I also didn't understand how you are showing the battery photo if it's inside a sealed unit.
The Items which you have ordered have 3 Keyways which are NOT evenly spaced, so that you can insert the plug into the socket only one wayJust checked again. My socket has a keyway between pins 1 and 2, but the diagram in your link shows no key.
Edit - I've ordered it as the data specs appear to match my own. Will see what turns up![]()
