Identify 2 pin connector
14 Jan 2005
Glamorgan
Hi All
I have a bit of old kit which has a rechargeable battery, but I have no charging lead.
Can anyone identify the connector from the attached pics?
Its a 12v battery I'm charging.
The OS diameter of the connector is approx 15mm.
Its a screw in type, not bayonet.
Cheers All
Doug
The 2 pin one in the photo appears to have locating slots and pegs so that you can only install it with the polarity being one way round.
Thanks all
I've now purchased a suitable SP13 connector.
Just need to establish which is +ve and -ve for pins 1 and 2 to wire up the charger.
Unfortunately the battery is in a sealed box so unable to see its wiring arrangement.
Is there a standard convention for possibly 1 = +ve and 2 = -ve?
Cheers
Doug
I would not think there is an infallible convention.
What voltage does a DC multimeter show on the pins of the underwater vessel?
You could perhaps ask the supplier/maker? https://www.arkmodel.com/contact_us.php
FWIW my wife's power wheelchair batteries have pin1 of a 3-pin XLR as +ve and pin 2 -ve for the charger input. BUT the output male 2-pin pin connector to the chair (unmarked numbers on the battery connector) in GX16 form has +ve on pin 2 and -ve on pin 1 if it would mate with your socket and keyway numbering.
All the pins/sockets are 'live' and showing the expected 24V via my multimeter.
My multimeter is showing -0.21v dc when connecting pos to pin 1 and neg to pin 2.
And +0.21v when leads are swapped.
Will go with pin 1 -ve and pin 2 +ve
I've also sent an email to the model website.
Cheers
Doug
I'm not sure how you know what kind of charger to use. The vendor seems to consider a 'smart charger' to be essential (whatever that may be). I also didn't understand how you are showing the battery photo if it's inside a sealed unit.
The battery pic is that of the ground station suitcase which is accessible.
The pic of the 2 pin socket is that of the remote ROV.
Both use the same charger, which I have and it fits ok to the ground station.
But its the adapter to connect to the ROV which is missing.
I'm happy with the connectors now. It just how to get the polarity correct.
Just checked again. My socket has a keyway between pins 1 and 2, but the diagram in your link shows no key. :(
Edit - I've ordered it as the data specs appear to match my own. Will see what turns up ;)
The Items which you have ordered have 3 Keyways which are NOT evenly spaced, so that you can insert the plug into the socket only one way
(Roughly speaking, the keyways are at the "points" of an isosceles triangle - NOT an equilateral triangle.)
However, since you have ordered the "pair",
you should be able to replace the existing socket with the new one.
Pretty unlikely on the sealed in socket of the underwater rover I'd suggest... without serious risk to that vehicle's water integrity.
If it had been simple / safe to do, the OP would have accessed the internal battery/wiring and not be asking about polarity.
Modern sealants are quite effective - unless you want to send a ROV down towards the "Titanic" !
The Plug has a "sealing ring" so the two units need to tightly screwed together.
The socket connectors actually "leak" - a bit of air.
Hence, it would be a good idea to provide additional (silicone) sealant around the soldered connections at the rear of the socket.
On other related sites, these are referred to as
"Waterproof Aviation Connectors"
