New Vaillant Boiler Making Clicking Noise
Had same problem. Vaillant will come out and tighten nuts on heat exchanger and the noise will stop! They know about this issue. The Vaillant tech told me they are picking up the problem as they go along.
I have a new Vaillant as above which does not fire up first time and clunks three times as the gas valve opens, shuts and opens again and it fires up second attempt. They have told me this is normal so I have submitted formal complaint to the dispute body. I'll never buy another Vaillant. It's been a nightmare since October 2022! Good luck!
Vaillant engineer tightened or loosened bolts and noise gone. Hopefully for good.
I would like to add to this thread…
I’m a council tenant and I had fitters fit me a vaillant
ecotec sustain in August 2024 it was nice… until a
few weeks past. I have the exact same problem as the
original poster had. I even went further and got so
mad at the thing it has dents in it and my neighbour
is wondering who I’m yelling at to; SHUT UP!”
Suffice to say called up vaillant. They were helpful,
they sent a guy round. At first he wasn’t happy that
my road required a parking permit. Secondly he wasn’t
happy that I didn’t go through the council first (if I did
it’d be weeks or months to get it sorted) he did very
stringent tests on the boiler. He gave me the excuses
I have read on here that others have been given.
Even when the boiler is - OFF it makes the noise.
He said its expansion and guess what… when he came
into the kitchen the little evil zombie boiler decided to
be as quiet as a mouse. No noise at all. It did make a
tiny “tap” sound and he said it’s normal. And it’s the
pipes. He suggested to cushion the pipes. So I got
some packaging material and shoved it behind the
pipes. Sounds even worse now. The sound comes
from the boiler itself. It’s a stupid little switch that
doesn’t know if it’s on or off. It does it if heating is
on or off, if taps are on or off, if boiler is on or off.
“CLACK, CLACK, CLACK, CLACK, CLACK” I make
YouTube videos and you can hear this thing in the
background. I think if I damage it enough they’ll
come out sand properly sort it!
I had one the EcoFit Pure installed a month ago and the snapping noise was becoming really annoying. I've just had one of their engineers out who knew exactly what the problem was, loosened some nuts and now it's completely silent for the first time since installation
OMG I am so happy to have found this thread as the guy who fitted the boiler insists it is normal to make these loud clicks. I have to work in the same room as the boiler behind me and the clicks are so loud they are not just distracting, they make me jump. Added to this it has tripped the mains switch twice, the boiler man got an extension lead and plugged it into another socket and left saying to call me if it happens again ie my electrics at fault even though last Worcester Bosh was there 25 years, quietly with no electric problems. I've had it for 2 weeks, I hate it but at least
this thread has given me hope and I'm going to chase Vaillant rather than the plumber who fitted it
recently had a Vaillant ecoFIT pure 825 installed, noticed this 'clicking' or 'popping' or 'snapping' sound and came across this thread
i've uploaded a video of it:
is this the same sound as what others have experienced?
i've noticed it only happens as the boiler is heating up/cooling down when the thermostat calls for central heating (it doesn't happen when hot water is called for--maybe the radiators need bleeding?)
there is normally 3-5 'pings' when the CH fires and then another 3-5 when it cools down
Mine is exactly same boiler and was making same noises. So i guess it needs same solution ;)
did you get yours fixed? if so how?
I think i got vaillant engineer or smth in (under warranty) and he said the screws are tightened too much at the factory inside (4 of them i think), loosened them up a bit and it got sorted.
Read the msgs in this topic, i think it is explained somehwere inside.
