- Joined
- 11 Jan 2004
- Messages
- 46,942
- Reaction score
- 4,021
- Country
As some know if they have followed my threads, I bought a 58" Hisense Freely TV for the lounge and moved the 50" LG Freeview Play TV into the den.
Before I had the LG, I had two old Samsung Freeview TVs from 2013 and 2014.
The aerial is chimney mounted and feeds both TVs. It is split at ground level and a co-ax goes off to a booster in the garage and then on to the den.
This arrangement worked fine with the Sammys.
Once in a very rare while in Summer there might have been some very minor picture disturbance but it was very infrequent and only in Summer.
Now the LG breaks up all the time.
And the Hisense even complained of loss of signal yesterday, even though it is a Freely set, although to be fair, it is supplied with a co-ax feed too.
Also the LG has memory issues and keeps on having to reload apps, there are breaks while it does this, and that drives me nuts.
Initially I was very happy with it, but not now...
But on to my main question.
I got a quote for a second independent aerial for the den TV and it was £300.
I can get a new Freely TV that doesn't need an aerial for that!
Is £300 the going rate?
Have you any other suggestions?
The layout at the moment is that the co-ax from the aerial runs down into a waterproof box at low level. This splits off through an airbrick to the lounge TV, which is buried in the wall, and the den TV, which goes all round the Wrekin via the booster to the back of the house, then under the floor and into the stud wall.
Cheers.
Cheers.
