It’s nuts. If I was qualified I’d do it myself.
And the domestic electrician, and I include myself, often got it wrong. Getting the manufacturer to put everything in a box, all pre-connected, so all the electrician had to do was connect it up, was a huge advance.
As the systems get bigger and bigger, it will not all fit in a box, and we get it where we need a heating and ventilation engineer who can work with complex systems, where radiators both heat and cool in an integrated way, connected to a building management system,
I remember working in Next in Chester, the sun would only hit the windows at one time of year, and when it happened the cooling could go up the creak, there was no heating, the lights heated the building, but seemed daft to have to phone London to ask them to adjust the cooling in Chester.BMS's are great fun. All the heating, cooling, and lighting, able to be controlled from one central location, and adjusted from there, via the network.
Oh dear - You are talking to the wrong folks if all they are saying is to throw a combi at it. Especially with more than one bathroom. (edit) Unfortunately, your husband is listening the wrong advice. What you're asking for is not really a difficult job, no. More money to them in a swap though, rather than a maintenance, easier too for some that don't have any open vent experience.
Nothing wrong with a gravity system if it's looked after. If one or 2 rads are filling with air all the time then I'm not surprised that the 'H' section with the feed and vent is blocked up and you are suffering from pumping over, one can feed the other.
Powerflush can be avoided if all the rads can be remove and manually flushed, or as suggested - system filled with cleaner, ran for a week or 2 then a drain/fill/drain/fill......
Which products would you recommend? And will they clear any sludge on/under the ground floor. I ask because my mum has no drain off lower than the ground floor rads.
If you post your location a bona fide heating engineer might get in touch.Symptoms: Central heating system conventional, two rads one upstairs one down filling with air weekly, pumping over a bit and more in summer, magnet sticking to some pipes in airing cupboard.
Action required according to advice here: powerflush, cut out and replace affected pipes if necessary. Add inhibitor and a magnetic filter.
Can I get anyone to do this? No. Umpteen engineers won’t touch it. Either they want to rip it out and replace with a combi or insist I must have an underground leak even though there’s no signs of damp or smell. We have lots of hot water which heats quickly and radiators are nice and hot when bled. Our house is warmer than our neighbours and our bills are less Our Worcester boiler has been a star for 12 years.
My husband is believing these engineers that a combi is best (we have two baths and a cloakroom) but I’m not sure. One engineer thought it would be easier for me to continually bleed a combi rather than radiators and if there was an underground leak why would I want to dig up concrete.
Is what I’m asking for a difficult job?
so when eventually this boiler goes what would you replace it with?
yes, a good cleaner that can happily sit in the system, X400/F3/MC3 etc can be added but the system does need to be flushed and filled and flushed and filled a few time to clear everything out once it's been in there a while. As long as you can mains flush the system clean through flow and return then the lower pipework should be able to be flushed out too.Which products would you recommend? And will they clear any sludge on/under the ground floor. I ask because my mum has no drain off lower than the ground floor rads. Apologies for potentially hijacking this thread.
Oh dearI’ll speak to hubbie cause one of the ‘slingers’ is his friend and get back
