Hi all. I need to remove a rad tomorrow.
I suspect that the TRV pin is stuck. When I open the bleed valve after closing both ends the water pee'd out
I removed the head and tried to push the pin down. It would not move. The pin looked like it had black gunk around it. Should I tap it with a hammer or try to pull it up before trying to push it down.
I need to remove the rad to paper behind it tomorrow before the customer gets back from holiday.
Thanks in advance.
Thanks in advance.
