- Joined
- 22 Jan 2007
- Messages
- 24,428
- Reaction score
- 3,655
- Country
It can't, it's too big for a 13A fuse.Thanks I think the electricians mentioned putting it on a fuse spur
This affair: https://www.amazon.co.uk/Instant-Electric-Water-Heater-Instantaneous/dp/B0DRCCHXPMThere the units
There is also a plumbing consideration, water when heated expands, and there needs to be room for it to expand when often there is a non-return valve on the supply. The under sink units we fitted into portacabins had a special tap, it controlled water into the heater, the outlet was open, and as the water heated up, it would drip out of the faucet.The load current in any part of the circuit should be unlikely to exceed for long periods the current-carrying capacity of the cable (Regulation 433.1.5 refers). This can generally be achieved by:
(i) locating socket-outlets to provide reasonable sharing of the load around the ring
(ii) not supplying immersion heaters, comprehensive electric space heating or loads of a similar profile from the ring circuit
(iii) connecting cookers, ovens and hobs with a rated power exceeding 2 kW on their own dedicated radial circuit
(iv) taking account of the total floor area being served. (Historically, limit of 100 m² has been adopted.)
It says on the picture, 10 litres. I just picked on at random. Think the one we used was 7 litres, which was ample for handwashing.What size reservoir does the one you linked have?
