Waterproofing shower over bath
27 Jan 2014
Essex
Hi, I am a plumbing,heating and gas engineer
I’d like to know opinions on waterproofing for a shower above bath
It’s a skim finish.
Would people still go straight on these days or tank the wet wall and use a tape around the bath edge and internal corners?
you mean the finish panels. I thought you meant tile backer boards as they are waterproof.
Tile backer boards are not waterproof ( water resistant) they just don’t deteriorate when wet .
4mm wall panels available .
Example
Seal around the bath then tile on to the plaster. Use a bonding agent if required.
Soo wouldn’t bother tanking the wet area (shower walls) or using a joint tape between bath and wall before tiling
