Gas safety question.
14 Nov 2013
Deal , Kent
Morning All,
Hope I have posted this in the correct category. Next week we are having a new kitchen fitted & we will be changing a duel fuel cooker for a built in all electric oven & hob. I'm assured by the kitchen fitters that the gas supply to the existing cooker is disconnected by means of a bayonet fitting & and will automatically seal it's self. My question is, is it safe to leave as it is.
We are on natural gas and have gas heating & hot water.
Thanks for any help,
Brian.
I would agree with @denso13 my father-in-law had a cooker removed by unplugging it, and the spigot did leak, the gas safe guy came and put a gauge at the meter, identified a gas leak, and went around the house until found. As an electrician I simply do not have the equipment to remove gas appliances safely.
Manometers are not expenive if you want to be certain
I have no desire to play with gas. OK, when a so-called gas safe guy sealed a flue with gaffa tape, I was tempered to DIY, my own house re-plastered were the gas fire went, so no need for gaffa tape to seal the flue plate to the flue, I was trained to work with gas, a 42" pipeline in Algeria, and a combined power, power station, and a gas drilling vessel, but still in my own home, I will employ someone who is used to working with domestic gas supplies. 9" gas pipes where the smallest I worked with.
neither are bubbles
Are you Fairy
confident on that? Detergent can burn, we were warned not to use it to draw cables, should use proper yellow 77.
vide
videos on youtube of them being cut and welded live
did i say washing up liquid ?
Need something to stop the water running away, be it soap, or detergent, or some other viscus liquid.
vide
Do you trust YouTube, so much AI now. To weld it I had to get it to 100 degrees C, and after welding raised to 600 degrees C at 100 degrees per hour max, held at 600 for an hour, then cooled at 50 degrees per hour max, do that with flammable gas in the pipe, no way, never mind the welding, and also doing the NDT not really practicable with gas in the pipe.
1. That is what purpose made leak detector fluid is for ,only been avialable for half a century at least
2. check them out definetly not AI been on youtube for decades and have spoke to guys i used to work with that have done it
.See the words LIVE and WELDING
