What’s going on here?
NRS
4 Oct 2025
I unscrewed an old plastic face plate to fit a new modern metal one and got more than I bargained for.
There is no back box. And we have a 2 way switch when this switch could only ever control one light. I can’t work out where the second cable comes from.
Can anyone advise me?
What do you think the screws screwed into.
Maybe there used to be two switches operating the light.
Make sure you earth your new metal face plate.
I think they are screwed into a scrappy bit of wood.
So I guess one cable is redundant and can be terminated?
Absolutely will be earthing the new metal faceplate
What probably happened, was....
In the dim and distant past, post 1960 judging by the fact that an earth seemed to be included, the lighting circuit was rewired, reusing the old conduit and timber box set in the wall - to avoid damaging the wall decoration. Timber boxes, and conduits in walls, predate 1950.
Your easiest fix, is to buy a suitable depth of metal box, try to break out the timber box, and set the new box in its stead.
It looks as if the faceplate screws were screwed into a couple of studs which, in turn, are screwed into something behind. However, the nearest to a 'back box' seems to be some rotting wood with (I think, but I am not certain) no obvious back.
I have wooden backboxes in my 1968 house
And This was another about the same age
In my experience, the wood is a ply wooden back box with dovetail joints. Originally, the faceplate screws would have been woodscrews that would have been driven straight into the backbox.
It has been butchered a tad at the top to let in the cables. I can't tell if that is capping or conduit.
The original switch drop could, of course, have been altered to make a two way.
In my experience, I have seen both wooden and metal back boxes from houses built in the 50s. The metal ones were standard size, but with fixed lugs and manufactured of very much thicker metal than today's efforts! Also the 50s boxes were black japanned.
I have also seen a different style of light switch in the early 90s, a bit like a 4 gang but portrait instead of landscape and slimmer. I can't for the life of me remember the brand. IIRC, I only ever saw them in 30s houses in Sale Moor, M23. They had wooden back boxes.
It was similar to this, but not the same.
Back to the cables in these switches. The conductors are not tinned, so I don't think they are imperial. The sleeving predates 1978.
I have known houses to be rewired, but the lazy beggers leave the old wooden boxes in!
I've even seen rewires where the spark used Ashley sockets (going back to the 80s) and 16mm lighting back boxes.
Can't believe he crammed it all in...
Can't believe that!
Maybe he had leftover stock?
I had a house built in 1968 and it had metal back boxes, cpcs to the lighting and a TN-C-S intake.
Surely not compliant with the 14th Ed, then! I'm positive that wood had gone out by then. I "grew up" on the 14th as, although the 15th was technically issued in 1981, it wasn't compulsory until 1985, hence why VO ELCBs were deleted from the regs in that year.
I also worked for a chap who was still stuck in the 14th Ed when the 16th came along!
I have wooden backboxes in my 1968 houseView attachment 410778
Can't believe that!
The whole estate built 1965-68 is wooden backboxes and very limited lighting CPC (only to 3 ceiling roses in order to provide the shaver socket in mine).
One can understand 1965/6, but you'd think once the regs kick in, 7/8 would be fully compliant. I'll have a butcher's in the morning and see if I can find anything in my copy.
My parents' house (1930s) still had some old wooden boxes left for light switches. The switch plates had little toothed lugs which pivoted outward as you tightened the mounting screws and they dug into the sides of the box.
Wish I'd kept an example.
