- Joined
- 18 Apr 2022
- Messages
- 7,404
- Reaction score
- 1,132
- Country
nope
- Modest Speed Reductions: A 2018 Department for Transport (DfT) review of signed-only 20mph limits found a reduction in median speed of less than 1mph.
So in other words 20mph limits have very little effect on journey times, and so anybody complaining that they make journeys take too long is talking complete bllx- it's just a false claim they've seized on to try to disguise the real reasons for their opposition.
Shall we look at some of the other findings from the study?
The majority of residents, non-resident drivers and cyclists (between 69% and 89%) perceive 20mph limits to be beneficial for residents, cyclists and pedestrians
The study shows that 20mph limits are generally supported and there is little call for the limit to be changed back to 30mph;
There is an established positive relationship between vehicle speed and injury collisions – the higher the speed, the more collisions and where collisions do occur, the higher the risk of a fatal injury at higher speeds.
- Limited Impact on Casualties: A study of a 20mph intervention in Belfast city centre found "little effect" on long-term outcomes such as collisions, casualties, and speed, outside of reducing traffic volume.
A 20 mph speed limit intervention implemented at city centre scale had little impact on long-term outcomes including road traffic collisions, casualties and speed, except for a reduction in traffic volume. Policymakers considering implementing 20 mph speed limit interventions should consider the fidelity, context and scale of implementation.
Belfast was a small-scale scheme, restricted to the city centre, where traffic speeds were already low.
The same report also says
Much larger effects have been demonstrated when 20 mph speed limit interventions are implemented city-wide in comparison to city centre. The example in Bristol has been used by many local authorities to support the introduction of 20 mph limits. Research evaluating the effectiveness of the city-wide 20 mph speed limit intervention in Bristol found statistically significant reductions in average traffic speeds of 2.7 mph, and a reduction in the number of fatal, serious and slight injuries from road traffic collisions, equating to estimated cost savings of over £15 million per year. Similarly, in a city-wide 20 mph speed limit intervention in Edinburgh, evidence highlighted that, following the implementation of the 20 mph policy, a further reduction in collision rates occurred. Specifically, the average number of collisions per month in Edinburgh in 1997 was 165, while in 2019 this number fell to 64.
- Low Compliance: Studies have noted that in some areas, compliance is poor, with up to 76% of drivers exceeding the 20mph limit in some zones, as reported in a 2024 analysis.
Low compliance is a reason for increasing enforcement in order to encourage compliance, not a reason to abandon 20mph limits. From the first report you referenced:
The most common area of concern across all user groups considered was around compliance, with most focus group and survey participants of the opinion that stronger enforcement measures are needed if 20mph limits are to be effective.
and of course with "every single" 20mph zone claiming 20-30% casualty reduction, we'd expect huge improvements in the fatality rate and total casualties. So where are they?
They are probably in places you refuse to look at.
