Can you get thin 22mm pipe insulation?
r_c
19 Jun 2016
I have 15mm pipe insulation that is quite thin (right most in photo below). I think about 6mm wide. Is it possible to get the same for 22mm pipe?
Smaller diameter pipework should have thicker insulation due to it freezing easier than large diameter pipework.
  • Thanks
Reactions: r_c
13mm might be the thinnest. Why do you want it so thin?
Thank you. It is just to provide a bit of insulation to the exposed pipework in an unheated utility room with our boiler. It is not to prevent freezing, just an attempt to help it retain whatever heat it has in the pipe.
But why not use a “normal” thickness? Why so thin?
The pipework is not far enough apart, and close to the wall. I could try cutting/trimming the foam rolls, but my previous attempts haven't been very succesful. As the pipes are not outside, I do not need to worry about freezing temperatures, and would just like to give them some insulation.
