I need to add a 22mm honeywell zone valve into a 15mm pipe that is both close to another pipe (about 1cm away) and close to the floor (carpet).
I'll be able to cut the pipe using a mini hacksaw blade and file the edge of the pipe etc, but what compression joints should I use?
Option A -
15mm pipe to 15-22mm converter (http://www.nsupplies.co.uk/22mm-brass-compression-reducing-coupling-to-15mm-1740-p.asp) to 22mm pipe to zone valve to 22mm pipe to 15-22mm converter to 15mm pipe
does that make sense?
or...
using these http://www.plumb-bay.com/endfeed-internal-reducer-22mm-15mm in place of the converters above?
I don't want to solder and i'm tight on space. What is easier?
Thanks[/url]
Option A -
or...
Thanks[/url]
