Adding zone valve to this pipe
15 Feb 2012
Manchester
I need to add a zone valve to the bottom pipe...
I was planning on using a 15-22mm reducer set (within the zone valve) to get the 15mm pipe to fit the 22mm zone valve.
It's going to be a tight fit...! Before I cut the pipe, will I actually be able to get it in there or is it going to be nightmare....?!
Advice please...
View media item 52641
I have to ask, why do you need to, it's obviously been quite happy for some time
I would say 'just' but it's hard to tell from the picture.
Getting to the nuts is gonna be a bugger.
Could it not go on the vertical bit of pipe?
Reason - zoning the heating.
The vertical bit of the pipe disappears up behind a radiator.
There is a plan b where there is marginally more room, but it will be more visible there.....
