Adding two extra loft lights to existing light
If I've understood you correctly, you'll probably have 2 cables coming out of the JB, one goes to the repositioned (roughly) central light which then daisy chains to an extra one and the second cable goes in the opposite direction to the final fitting.
In the interests of being condescending, don't forget some cable clips.
I was thinking 3 separate cables out the junction box to the three fittings, but what you suggest makes sense actually: one cable out the JB to the repositioned (central) light and then running one daisy chain off the central light to one end of the loft. Then a second wire out the juncction box to the final fitting at the opposite end.
I don’t suppose there’s any advantage to running 3 separate cables out to the lights from JB? May as well daisy chain one of them if possible?
And yes I’ll make sure everything is clipped to the wooden beams and secure
I quite often do this sort of thing if the lights have pathetically small terminals/wiring space where getting 2 cables in would be difficult/impossible. Some light fitting designers deserve to have their heads kicked in.
Further to my recent posts above, I’ve bought some fittings and cable etc to complete my project, but one thing that has confused me already is with the batten holders and getting the cable into the fitting itself in a way I originally planned.
I bought three BG White Bayonet cap (B22) Straight Batten lampholder 763 specifically because the description said they have knockouts for surface wiring, which I took to mean that I could get the cable in through a hole in side of the base (the screw cap part) rather than in round the back. Reason for this is I want them flush mounted to the wooden beams in the loft but I don’t want to drill holes through the beams to get the cables in.
Only I’ve taken one to bits and I can’t find anywhere in the screw cap base part that would knockout? Have I misunderstood what it means by knockout?
Anyone able to offer any advice?
