Converting a double socket - do these parts exist?
Depends on the wattage of the heater, (and the condition of the plug and socket) really!
So if I have the flex cable from the heater panel running down some surface mounted trunking on the wall, into a boost switch at chest height, out and then down to socket level where the flex just comes out of the trunking on a 13A plug, that will be ok? Will look a bit bodge?
Heater I think is 1500 W.
As opposed to what?
I.e. with the FCU, is the boost switch up or downstream of it?
As opposed to what?
Here's a picture. Socket is behind furniture unit (green blob), flex cable (green) runs up the wall, across the beam and to the IR heater mounted up high. I want to fit a boost timer (time guard tgbt4 or fbt4n) where the purple blob is.
