Removing a 1970 WC
4 Sep 2009
Worcestershire, UK
Currently in the process of updating a 1970's house. The downstairs toilet has the original WC and I want to remove it but I'm a bit concerned as it looks like it is cemented in place and it looks a lot to be a larger diameter. I want to cap it off so that I can replace it with a new one so wondered if I am likely to have any problems.
Should be ok, and does look cemented in. Once the pan is dislodged, you should be able to remove the drain connection easily.
OP,
When you say "cap it off" do you want to seal the pipe stub after removing the present WC or does that mean you are intending to replace the existing S-Trap WC with a modern P-Trap WC or are you going back with a modern S-Trap WC?
But if you are going to re-use the present soil pipe outlet then the stub sticking up from the floor is irrelevant &, using appropriate reciprocating saw blades, it could be cut off flush with the FFL.
FWIW: Now-a-days, installing S-Trap WC's is frowned on by some BCO's.
I want to cap it off temporarily until the room has been updated, then I will fit a new WC but in a slightly different position. In order to do that I will need to connect with either a flexible connector or other suitable alternative.
OP,
But to repeat my above: will the new WC be an S-Trap or a P-Trap WC?
Why not post the make and ID number of your selected WC?
Do you understand why I suggested removing the soil pipe stub?
Until you post the new WC type, & show us where it will be located then there's not much we can suggest to help you?
It will be a P trap and will be located 6 inches to the left of the soil pipe.
Thank you for all your assistance.
No problem, just come back if you need any further help once you know what's what.
OP,
"6 inches to the left" why are you moving the WC - Is it to make room on the wall for a basin or some other fixture?
6 inches centre to centre might create another problem - so, if you want further help then definitely post make and ID, & a pic of the WC compartment?
If you really want to position the new toilet 6" to the left you'll need to think very carefully about how you'll connect it to the existing soil pipe. Even if the existing soil pipe is sawn off flush with the floor, you'll need to raise the new toilet quite a few extra inches off the floor to be able to fit in the 1 or 2 bends in its outlet pipe (depending on the new toilet's outlet) that will be needed to connect to the existing soil pipe. Also be aware that a flexible connector, bent to fit, will be quite prone to blockage and also won't look very pleasing.
It will be to the left and forward a few inches as I will be using a "back to the wall" WC and cupboard if that makes sense.
