hoover am110 six drum wont turn
28 May 2004
hi there ive just put a new motor in machine but still wont turn it lights up ok and the programer moves but the motor wont turn thank you :( hoover am 110 six
there are three versions with this model no.if when viewed from the back bottom left hand side there is a PCB check for dry joints.
not so much the edge connectors but the solder underside of two black relays on board.if all ok could be the board or the timer.
checked the relays on underside one solder joint loose . soldered it but still not working do you think its the board .
This worked for me.
I have a Hoover AM120, it must use the same board as the AM110. Drum would not spin or wash until I'd re-soldered three pins under the black relays, there's not enough copper around the pins, one of them is particularly bad and only solderable where the track meets the pin.
Many thanks to assuhors.
