Hi, I’ve tried all the supermarket weed killing products on my driveway without much success, recently a friend told me that
Salt kills most weeds if you give them a good coating. Or if you have time covering them with black plastic and leaving for a season
As I said weed killer doesn’t work….That's a disinfectant, just buy weediller, it's not expensive.
You must have bought a Jimmy White one. Buy proper weedkiller.As I said weed killer doesn’t work….
The flame only burns off the leaf and it will regrow from the root. Dandelions are brilliant at doing that, try and pull them out and they will snap leaving the root.If you are going to use weedkiller, it's important to read and follow the instructions carefully, in order for it to work.
Something that does work is a flame weeder - it simply cooks the cells of the plant.
Weediller or weed killerYou must have bought a Jimmy White one. Buy proper weediller.
Thanks, I've fixed it. And, I've fired my poofreader.Weediller or weed killer![]()
Not exactly, you don't need to burn the leaves, you're just heating it enough to damage the cells.The flame only burns off the leaf and it will regrow from the root. Dandelions are brilliant at doing that, try and pull them out and they will snap leaving the root.
Did you try Pathclear?
How long did it work for?
Did you disturb the surface by scratching or hosing?
