Shower cubicle install
10 Nov 2013
West Midlands
Hi I have the following downstairs bathroom that needs to be fitted. The shower area is recessed about 30mm, sand filled with a large waste pipe. Guessing the recess can be topped up with more sand then compacted and then the shower trap waste fed into this?
Another question I have is that I have seen vapour barrier sheets installed around the shower area- is this worth doing?
Thanks in advance.
Yes.
I've never used anything like that.
So do I need to use that membrane? I’ve seen boards about 5mm thick and flexible sheets as well…wanted to make sure I do whatever is needed before tiling
Hi again, does the shower tray need to sit on a sand and cement mix? I originally thought a compacted base of building sand was ok but reading a lot of posts about sand and cement mix? Guessing the mix will stop movement but a compacted sand option may allow movement?
Any advice appreciated thanks.
Not just sand, use a flexible tile adhesive.
So use the adhesive where the tray meets the floor tiles and fill the void with building sand?
I'd screed the floor with a weak mortar mix, then adhesive when the screed is dry.
Also with the suite I have these waste traps for the shower tray. But my issue is that there is no U bend so potentially the smell flowing up the pipe. Have I got the wrong shower waste? The U bend I’ve ordered just doesn’t work as the fitments are the wrong way? Thanks for any advice…
All built in to the black shower trap in your photo.
Thanks I wasn’t sure if the black trap would block the smells so just thought I’d check first - thanks
Thanks @denso13 ivd got to this point now. So plan is I will sand/cement the void with a dry mix, compact, I may shutter off the piping for the drain rather than cementing that in? Put sharp sand or building sand into it?
Once dry I still have some proflex tile adhesive I can build up the level on the tiles and screeded void and then drop tray into place and put some weight on there and leave to set overnight?
Thanks in advance
The instructions work on basis that the floor is already solid and flat. It mentions a high grade flexible silicone adhesive to cover full area to place tray on top of . The usual silicone around the edges when fitting the tray against walls. It’s the build up of void that I want to make sure I get right
