the thorny issue of lime
24 Nov 2004
I have developed a theory on which I would welcome comments
Specifically Northern Orkney Islands traditional building, where the main material is locally quarried "Caithness Flagstone". The actual stone used in any given building is somewhat variable in quality, with certain stones being soft mudstone and some stones much harder tending almost to metamorphic., it's a fairly soft sedimentary stone anyway. Crucially to this argument, I contend that at least 20 - 40% of any given traditional building in the area is made of this permeable, rather porous mudstone/siltstone. This variability in the stone used in a building may be purposeful but more likely just accidental.
"traditional" building is walls 2-3' thick composed of two roughly dressed outer skins and a fill of chossy broken stone.
unmodified Clay-ey earth seems to have been used as a filler or mortar during the buiilding process.
usually some evidence of lime mortar pointing on the external (and internal) surfaces.
this lime mortar sometimes extends to a full render on the outside, and also sometimes a smoothish render on the inside, made of a lime which seems to use finer sand than is typically used outside. The outside render & pointing where present appears to be made with local beach sand.
Damp-proof measures near ground level appear to have simply not featured in historic traditional building. Probably location was the only consideration - site the house on a relatively naturally dry piece of ground. The floor in a traditional house was the compacted soil. Flagstones (where used) were simply laid on the soil. The first modern floors appear to have been a thin layer of concrete over the soil.
Consider the following observations:
The climate in Northern Scotland is noticably wetter (and warmer - or at least, less frosty!) in the past 20 years than it has been in the preceding 200-odd years.
The traditional use of houses has changed in the last generation, and it is now very rare indeed to find the usual situation of a coal-fired range in the middle of the house with a wife tending it 24-7.
expectations of comfort etc have increased, so that living with damp & mould is now unacceptable, as are the natural draughts of a traditional house that would have contributed to useful ventilation.
labour cost has risen relatively, so it is more difficult to keep building management in check (nobody considers repointing or painting or roof repairs annually any more) likewise much more relatively expensive to work at height now than ever in the past.
That's the backdrop as I see it.
Maintenance of such a traditional local builing for heritage/aesthetic purposes is a challenge.
Lime mortar has fairly recently been used again locally for rendering & pointing with this "breathability" thing being touted as the key to keeping an old house weatherproof and dry.
When done right, I don't doubt that there is something in this: moisture that naturally collects into the structure possibly has a chance to evaporate off through the "porous" lime mortar.
However
I think that the lime mortar is sacrificial: in the current weather it is eroding faster than ever, it's not cost-effective to have the plasterer back every year to keep on top of it, and moreover the climate is damper now through the year that it has been in the past, so the seasonal evaporation mechanism is falling over.
The lime is probably (like all other materials) not as "good" as it was in the old days in some way. don't ask me how but paints are not as toxic as they used to be, therefore not as good, likewise wood, steel, plastics. and probably in some way this is true for lime.
The "fix" that I am favouring at the moment for maintenance of trad old stone is to carefully point stonework in a strong cement mortar, leaving strategic miniature gaps in the irregular pointing where the stone has naturally formed a water-shedding or somewhat protected or hidden vent. These gaps are few and far between.
Never to fully render old stonework, apart from in small patches where a poor stone is obviously spalling.
Leave as much vertical face of stone exposed as possible.
The strategy being that the natural porosity/permeability of the stone face will have to provide any breathability.
the argument of frost spalling saturated stonework is negligible, owing to the (slightly) warmer climate.
The technique is a compromise between reduced permeability of the pointing medium (strong cement vs lime-mortar) with a longer-lasting and more weatherproof finished product (finished product being a bit of worked-over masonry)
I contend that the cement mortar wins out because times (especially expectations, & weather) have changed, leading to the lime mortar being a relatively unsuitable material for this area.
There are probably places (drierplaces with less wind-driven horizontal precipitation - and with a genuine risk of frosting) where the lime mortar technique is more suitable than cement.
enough of an essay. I look forward to arguments against.
Yes.
No.
Better sacrificial mortar than eroding the stones. If the evaporation is through the stones, rather than the mortar, then the stones will spall. That is irreversible, unlike eroding sacrificial lime mortar which can be replaced. This is all well established.
The rest of your post sounds like “everything is rubbish, not like in the olden days”. Have you been watching too much “nostalgia channel” crap on YouTube?
why would the stones spall with evaporation?
I think you need to google that. I’m sure a few PhDs have been earned by materials scientists studying the subject. While I cannot explain the exact mechanism, it is certainly what happens.
There's a number of reasons why a strong mix shouldn't be used.
Firstly, the rest of the wall will expand and contract differently to the pointing, which will break the edges of the stone.
Also moisture is better soaking into the joints, as the freeze/thaw and salts brought to the surface are better in the joints and breaking them up than the stone. Salts expand when they crystallize, as does water when it freezes.
A strong sand/cement mix also tends to crack easier and let moisture into the wall.
I looked into Lime Mortar a couple of years ago. My property has cement mortar on the brickwork but proper Lime mortar on the internal plastering....bright white chunks, very dusty when disturbed and lots of horse hair. The walls are lath and plaster and super flexible, amazing how they've lasted the 100 odd years. Anyway, when it came to repairing sections that had been damaged by a electrical re-wire, I used a 6:1:1 mix, apparently the closest ( softest ) mix you can use.......that mix was nice and fluffy to spread but now dried, in no way resembles the original lime mix. The cement mix is hard and brittle.
For inside plastering a pure air lime is normally used, which is the softest and most breathable mix. A 6/1/1 mix is closer in strength to an NHL 3.5 mix. This is normally for exterior work. You could have used a 1/2/9 cement/lime/sand mix, which is similar in strength to an NHL 2 mix.
I see what you mean. I was meaning that the olden days were just different in so many ways, chiefly to this argument the perceived lack of time, relatively higher cost of labour, and harsher precipitation in this region meaning that doing it "properly" is no longer as viable as it was.
so I was examining other approaches.
the action of water on local stone does indeed cause spalling (in this area it appears as delamination of the micro strata within the stone), but not all the stone in this area seems to be subject to it.
However, provided this spalled stone is left undisturbed, it still bears compressive load reasonably well.
when the mud/clay/ smaller particles forming the core of a wall are able to wash through and out of a wall (for example in a situation where the original lime mortar has failed and not been replaced, then the wall will start to move and rapidly deteriorate (relatively rapidly, none of these old buildings will collapse overnight, it is almost a geological process of slumping)
Sandstone should be laid on it's natural bed. If it isn't the face can spall. Imagine it as a loaf of sliced bread. If the face has the slices facing the weather they can delaminate.
Quite so, but the stone can still spall in any orientation. is that bad? seems not as long as the layers cannot displace too far.
internal pointing. purpose (as I see it) is two-fold:
1. to reduce the natural dusting effect that would otherwise occur from the traditional clay filler-mortar material and/or lime-plaster render.
2. to give an aesthetic effect
If framing & lining an internal masonry wall, the goal is to reduce the dusting & natural fall of masonry related debris into the void which may then (over time) cause bridging between the masonry and the back of the framing.
if part or parts of the internal masonry are going to be exposed (eg for aesthetic effect) then it may be desirable to not have them dusting-off over time.
acceptable to use a cement mortar in this area?
or is this surface required to "breathe" also?
