Air in the system.
Corrosion inside radiators causes gas so treatment inhibitors stop this.
You can bleed system and check the automatic air vents are working and sometimes they need a tap or fiddle with air cap.
Seek out a plumber if you can't sort yourself.
Also combi boilers randomly pump water around even with heating off to cool themselves as they get hot heating water
Air in the system.
It's a sealed system.
Pressure should not drop. I top mine maybe once a year but that's normal through natural pressure drop.
Call the plumbers back for advice and talk about it so you understand.
Tell them about the air bubbles.
