contrails (chemtrails)
You can do your own and see for yourself, I am not taking a screenshot shot of the map showing where I live thanks.
Anyone can do it, see a plane with the chem characteristics look in the app and check it's height over the entire length of the chemtrail.
They are all over 30k feet. Go and Google if the atmosphere temp, humidity can change massively at those high altitudes, remember same altitude but just 1,000 feet either side front and back
I don't believe that's what you've seen because ATC won't allow that. Civilian Jets aren't allowed to get that close to each other.
Yes they are contrails and not chemtrails, have you not been paying attention to the difference.
I told you there are no chemtrails at night and the fact that you cannot find any after 2 trys proves that.
No, because I can't work out what you would class as a 'Chemtrail' exactly. Plus I have every confidence that even if I did find one you'd claim it was a leftover from the daytime or in preparation for the morning.
I have not edited your post.
Which is obvious to anyone blessed with the gift of sight.
I posted it in its entirety, then reposted the part I want to emphasise.
Because on my phone, I do not have the bold function.
And I can't remember the square bracket way to bold text.
BS, you edited it
Highlight it and tap the "B"
To show how Aveatry is talking nonsense here is a serious incident report where two jet planes were on a converging course at similar altitudes (500 feet separation ) and approached to as close as 5 nautical miles before they took emergency action.
Aveatry is claiming to have seen an even more serious incident and it hasn't even been mentioned in the press.
Rubbish attempt i said they were in the same patch of sky but not at the same time and I have said I did not recall the 100s of feet, only the 1000s of feet which was the same.
So far the only argument to debunk you have but up so far is on the same level of swamp gas. :LOL:
Your argument is that its different conditions 38000f high in patches of 500f that cause the chemtrails. But then there are no on off cemtrails ever in this country which would prove your theory. They are either there or they are not.
Liar liar pants on fire
You haven't proved anything where is the lie there.
The lie is in your post because you have edited what I said.
Here it is in full.
They are all over 30k feet. Go and Google if the atmosphere temp, humidity can change massively at those high altitudes, remember same altitude but just 1,000 feet either side front and back.
I am asking you to check if atmospheric conditions can vary at a given height, in this case a single height over 30k and this bit ----
Was so you didn't google and come back with proof of variation but it was miles apart.
Remember also I said 2 minutes apart which would give a separation of 88,000 feet.
BS, you edited it
You might want to look up the definition of "edit".
And see that what I did - reproduce in full then, separately, a part for emphasis - doesn't meet the definition.
Out of you and I, only one of us is full of BS.
And it ain't me (y)
And it ain't me (y)
Here - completely removing everything in my post apart from one word - stop it and stop lying. Reverting to heavily editing someone’s post and then lying about it does not help your case when you are trying to debunk chemtrails.
That's the whole part of Brigadiers' post where he quoted you.
If you click on the link, you'll see they're identical. Brigadier just repeated the two words that were contained in your whole post to draw attention to them.
Now if you were unaware of the words that you typed, and couldn't make the connection, that's your problem.
Just for those not paying attention. Today there are no chemtrails, only normal short lived contrails and normal clouds.
And is that through your 'round, square or arched' window today?
:mrgreen:
My eyes, step away from your computer and go outside and look you will not see any horizon to horizon, stay in the sky for hours gradually spreading out chemtrails.
I know you won't see any because there are none in my sky's today and it will be the same over the whole of England.
When there are chemtrails it will also be over the whole of England
I'll let the airports know. (y)
England is more than you can see from your patio.
