When you say horizontal, how do you mean? Just a normal convecting radiator or a designer type? You do get flat panel, contemporary looking rads that are convectors BTW.
You really can have that if you prefer, output sized appropriately.The vertical one we were looking is this one, it's aluminium but not sure what type
Thanks, from the online calculators the room would need about 5700-6000 BTU for the living room (room is only 4x4m - 2.3 ceiling). Do you think going to a 8000BTU is a good option?You really can have that if you prefer, output sized appropriately.
I hadn't really thought about us having to deal with potential problems if buying directly.
Also I've seen people talk about doing heat loos survey but it does look quite expensive. Our house is from the mid 1990 so fairly recent.
Thanks, i'll check with them. Would that be good if that's the case?Heat loss calcs are designed to provide the amount of heat that a given room can lose in an hour in Kw, that is then matched to the output of the radiators at a given delta that can then replace that heat loss, that is then designed to ensure that the space is comfortable to be in. Unfortunately that doesn't cater for how a given radiator may heat that room up and how that then feels to the user. They are useful when replacing like for like, as the performance of that type of radiator is understood but when changing the type of radiator to others that heat the space differently, then that information doesn't tend to be as real world useful
Looking at the specs of that vertical rad suggest that it may have hollow tubes which could act as convectors, a call to the supplier would confirm though.
I disagree, but opinions do differ, that's fine.because they just fail to heat a decent sized room properly.
AbsolutelyI disagree, but opinions do differ, that's fine.
If you can only fit one rad then I'd use a conventional, albeit contemporary design, if you want it to look good. A Type22(K2) radiator behind the couch is proven to work well, as long as there is a reasonable air supply allowed to get to the bottom of the rad and a little space left between the rad and the back of the couch. I'm sure you will notice the difference immediately.Currently we don't really have any space to put a horizontal radiator except behind the sofa as the layout is tricky, but we thought that it could damage the sofa and block a lot of the heat anyway?
Yeah we will upgrade the valves to TRV on all the radiators upstairs.If you can only fit one rad then I'd use a conventional, albeit contemporary design if you want it to look good, Type22(K2) radiator behind the couch, that's certainly proven to work well, as long as there is a reasonable air supply allowed to get to the bottom of the rad and a little space left between the rad and the back of the couch.
Especially if a column has been used before and didn't do the job and the CH had to be run a lot longer, which is obviously inefficient and costs more to heat up the room properly. May also be time to upgrade the valves to TRV's
