new Dishwasher not turning on - A simple error?
15 Apr 2006
Manchester
I've just installed a new Beko dishwasher.
Plumbed it in etc, when I turn the mains on all the lights on the console/door flash briefly and it beeps so power is definitely working but then it goes off. When I press the on/off button to begin, nothing happens.
Hoping I've just made a simple mistake? Any thoughts?
This makes no sense. Have you confirmed correct voltage? Is it on a plug-top or hard wired?
I had a bosch washing machine, brand new, plugged in, lit up then nothing. Took them 7 days to take it away and deliver a new one.
Is the waste pipe blanking plug removed? (Apologies if this is a replacement of an existing dw and the drainage is already working)
I've already connected it into the plumbing. - Presumably that would be at the end of the waste pipe where it connects?
Yes. It's worth double checking as if the blanking plug is in the drain connector then a dishwasher will cut out as soon as you turn on as it tries to do a small drain pump before it can do the cycle
