Best way to sand floorboards around radiators?
25 Nov 2006
London
Hello
I've just sanded floorboards with a floor sander and edging sander. Now I've got to get into the corners and around the radiator pipes. The boards were already stained and the floor sander needed quite a few sheets of 24 grit , so I can see it's not going to be easy.
I've had a go with a mouse sander and 40 grit but it barely made a mark. Is there a better tool that would do it? Thanks
Same edge sander but protect the pipes with something. no need to get right up to the pipe as a wooden pipe collar will cover
Thanks - I was hoping to not have to take the radiators off so was hoping for something smaller.
I find the vibrating type of sanders rubbish sounds like you will be better off with an angle grinder with a sandpaper disks, you can buy a cheap one with 2 years warranty for les than hiring the edger for 2 or 1 day
Thank you, that's sounds like a plan. I have got a Titan angle grinder that I use occasionally so will look out for a compatible fitting. As you say, those small sanders aren't up to it.
I found the parts for the angle grinder so hopefully that will work.
I also came across a file belt sander but it might not be powerful enough for this type of job. I think I'll get one anyway as it looks like a useful tool for sanding in small areas like staircase spindles.
Both of these can be pretty savage unless you're very careful
And throw dust everywhere although you can buy shrouds for them that you connect a vacuum to. I made one myself which worked very well so I imagine the proper ones are very good
If the floor varnish is oil based, you can use old skool methyl chloride paint stripper to remove the varnish. If the stain is oil based you can hit is a few coats of white spirit and then sand it.
If waterbased, cellulose thinners will soften the waterbased varnish.
If you want to purchase a small quantity of methyl chloride, PM me, I can send you a link to a company that sells small quantities- btw, I have no links to the company (other than having purchased from them last year).
