In post #31, thread "Water Hammer" you have a schematic showing a pressure gauge, you say the mains pressure is normally 4.5bar?, did you take this pressure statically, with no flow and before you installed the PRV?, can you post this schematic here showing the position of the PRV and (even roughly) include the distances between the various items.
Edit, you do show the schematic with the PRV, post #12, here, but not the PG, I think you also said that this PG was also remaining at 8bar even after closing off the mains due to a NRV, if you just temporarily slacken the PG connection to give a small leak off dribble then it will read properly for a few tests without having to remove the NRV.
