Piping up bath taps
16 Jul 2009
Hull
What's best, push fit flexis, compression flexis or 3/4 to 15mm end feed tap connectors and fibre washers?
If it is mains fed hot and cold, then they will all work adequately well, size of feeds dependent. Even copper all the way up with push fit 15mm>3/4" tap connectors would work (edit) just as well
What is the proper, pro way though, that's a whole other question all together ;)
Agreed, copper is proper :wink:
But sometimes plastic can be fantastic :whistle: :p
