- Joined
- 3 Feb 2025
- Messages
- 6
- Reaction score
- 0
- Country
Hey all, I’m in the process of a big garden renovation that I’m doing myself, including a load of bricklaying.
One of the things I’m going to be building is a garden office / drum room. For maximum sound isolation I’m planning on building it as a double leaf block work using the dense 7n blocks.
Now my biggest decision at the moment is how to do the foundations for it. Due to space I was planning on a concrete slab with rebar (and the standard type 1 mot underneath) just slightly wider and longer than the office size.
The ground under that is a lot of sandstone so it should have a stable base under the slab. But after some research I’m unsure if that will be safe given the weight of a double skin building near the edge of the slab, I’ve read that it could potentially lead to cracking of the slab and that I should really do trench footings for it.
Sadly though given how wide the trenches would need to be it would mean I have to reposition it and shrink the size of the room down.
So what I’m wondering is, would the slab actually work in this situation or would I be risking in cracking and damaging the building, anyone else had experience with something similar?
